The following table lists recommended versions for the components that make up the Tunnel Concentrator solution. We recommend that you run the latest version for each component.
| Solution Components | Supported Versions |
| Universal Compute Platform (1130C, 2130C, 3150C, or 4120C) | Universal Compute Platform v5.14.01 or later |
| Extreme Platform ONE Networking | Extreme Platform ONE Networking v25.13 or later |
| ExtremeCloud IQ |
ExtremeCloud IQ (Classic) v25.12 or later Note: Tunnel Concentrator does not support
ExtremeCloud IQ (New).
| ExtremeCloud IQ Controller | ExtremeCloud IQ Controller v10.20.01 or later |
| Access points |
If your management entity is Extreme Platform ONE Networking, see Extreme Platform ONE Networking Release Notes for a list of supported access points. If your management entity is ExtremeCloud IQ, see ExtremeCloud IQ (Classic) Release Notes for a list of supported access points. If your management entity is ExtremeCloud IQ Controller, see ExtremeCloud IQ Controller Release Notes for a list of supported access points. Note: The following APs have been tested with
Tunnel Concentrator in a GRE-tunneling deployment:
Refer to the following table for information on supported Tunnel Concentrator capacities for each Universal Compute Platform hardware option.
| Installed on | Supported Capacities |
| 1130C |
| 2130C |
| 3150C |
| 4120C |
Make sure to take your redundancy setup into consideration when scaling your deployment:
