ExtremeCloud‌ IQ Configuration
If you are using ExtremeCloud IQ (Classic) as your management application, complete the tasks in the following task flow to provision tunneling services using Tunnel Concentrator.
Before you Begin
  • Tunnel Concentrator(s) must be installed already. For details, see Installation.
  • You must have an existing Network Policy with at least one SSID. You will configure Tunnel Concentrator within these elements. For help with Network Policies and SSIDs, see ExtremeCloud IQ (Classic) User Guide.
Table 1. Tunnel Concentrator Task Flow for ExtremeCloud IQ (Classic)
ProcedureDescription
1Add Tunnel ConcentratorsOnboard your newly installed Tunnel Concentrator instances to your management application.
2Configure Tunnel Concentrator ServiceConfigure a tunneling service that uses a single instance of Tunnel Concentrator or a redundant HA pair of instances.
3Configure User Profile with Tunnel ConcentratorAssign your Tunnel Concentrator service to a User Profile.
4Configure SSID for Tunnel ConcentratorAssign the User Profile with the Tunnel Concentrator settings to SSIDs within a Network Policy.
5Deploy Network PolicyComplete a delta push to deploy the Network Policy to affected devices.
Alternative Configuration Flow
Optionally, you can also use a streamlined configuration flow where you assign all settings from the Network Policy. See ExtremeCloud‌ IQ (Classic) Configuration Example (Alternative Flow) for a configuration example that uses this approach.
