Installation Example
This example provides sample settings for an installation of a single instance of Tunnel Concentrator on ExtremeCloud Edge.
The first three sets of settings are configured on Universal Compute Platform during ExtremeCloud Edge – Self-Orchestration configuration that prepares the host for Tunnel Concentrator. The remaining settings are part of the Tunnel Concentrator installation and engine deployment.
  • This example provides sample settings, but not detailed procedures. For step-by-step procedures, see Installation Task Flow.
  • This example does not include LAG.
Basic Configuration Wizard (on Universal Compute Platform)
When you log in to Universal Compute Platform for the first time, the Basic Configuration Wizard starts. Assign the following settings:
ICC1 Port IP Address=192.168.100.14
ICC1 Port Netmask =255.255.255.0
ICC1 Port VRRP IP Address=
ICC1 Port VRRP Priority=100
ICC1 Port VRRP Router ID=1
Enable Lag on ICC1 Port=n
Data Port=Port 1
IP address=10.10.10.1
Netmask=255.255.255.0
VLAN ID=1
Tagged frames=n
Management on this interface=y
Host Name=UCP_01
Domain Name=extremenetworks.com
Primary DNS server=8.8.8.8
Default Gateway=192.168.100.1
Timezone=America/Detroit
NTP server 1=time.nist.gov
Standalone Cluster Creation (on Universal Compute Platform)
On the Universal Compute Platform GUI, go to Cluster Settings > Cluster Configuration and create the standalone cluster with the following settings:
  • Deployment Type=ExtremeCloud Edge – Self-Orchestration
  • Cluster Node Information=Standalone
  • ICC IP Address=192.168.100.14
  • Pod Network IP Address=10.96.0.0
  • Pod Network CIDR=16
  • Service Network IP Address=10.97.0.0
  • Service Network CIDR=16
Cluster Configuration Wizard - Select the Deployment Type
VRRP Configuration (on Data Port of Universal Compute Platform)
After the cluster is created, go to Administration > System > Network Setup and configure VRRP on the data port that you configured using the wizard. Add the following VRRP settings to the existing port configuration:
  • Virtual IP Address=10.10.10.2
  • Priority=100
  • Router ID=10
Configure VRRP on Data Port
Tunnel Concentrator Installation and Engine Deployment
On Universal Compute Platform, go to Engines > Installation and Install the Tunnel Concentrator application.
After installation, select the link for the freshly installed instance. On the Deploy Engine page, assign the following engine settings and deploy the engine:
  • Node Affinity=UCP_01.extremenetworks.com
  • Port1=Port1(Intel GBase-T) VF01
  • Port2=Port2(Intel GBase-T) VF01
  • Port3=Port3(Intel GBase-T) VF01
  • Port4=Port4(Intel GBase-T) VF01
Deploy Tunnel Concentrator Engine
Assign a Virtual IP Address
Make a note of the serial number and then select the Network Service Configuration tab. Assign the VRRP address that you assigned in the port configuration to Tunnel Concentrator using the following setting:
  • Assigned Virtual IP Address=10.10.10.2
Select the Instance web interface link (https://10.10.10.2:5825) to launch the Tunnel Concentrator GUI at the login screen.
