Field | Description |
Interface | The software representation of the physical port. |
State | Indicates if the port is enabled or disabled. |
Port Type | The interface port type. This field is read only. |
Native VLAN | The native (untagged) VLAN assigned to frames that do not have any 802.1Q VLAN tags in their headers. |
Allowed VLANs |
The VLANs, including the native VLAN, that you want the trunk port to permit. You can list the VLANs individually, separated by commas, or as a range of VLANs using a hyphen. Alternatively, you can enter the word all in this field to support all existing VLANs previously configured in the network policy (the default). |
Fabric Attach |
Transmission Type | Select one of the following options:
Speed | The speed the Ethernet port uses to communicate with the connected device. |
Green Ethernet (AP4020 and AP5020 Only) | Select for AP5020 devices to allow physical layer transmitters to consume less power when they are in a state of idleness or low data activity. |
LLDP | Select for devices to advertise identities, status, and capabilities
to each other. Devices can transmit data about themselves and receive transmitted data from other devices, but they cannot solicit and retrieve data from other devices. |
CDP | Select for devices to advertise an IP address that can send and receive SNMP traps. |
MCast Filter | Select to enable Multicast Rate Limiting on the interface for multicast/ broadcast traffic. |
Multicast Rate Limit | Set the maximum rate (in Kbs) for incoming multicast traffic for the interface. |
