Do the following to configure ERSPAN Mirroring where the source port is a Physical Ethernet port and the destination ports are a RSPAN VLAN and another Physical Ethernet port.
SLX# configure terminal
SLX (config)# interface ethernet 0/2
SLX (conf-if-eth-0/2)# lldp disable
SLX (conf-if-eth-0/2)# exit
SLX (config)# monitor session 32 SLX (config-session-32)#
SLX (config-session-32)# source ethernet 0/1 destination erspan 1 source-ip
10.10.10.1 destination-ip 10.20.20.1 vrf vrf-for-erspan direction both
SLX (config-session-28)#
The ingress traffic on ethernet port 0/1 will now be mirrored to the IP 10.20.20.1 over GRE tunnel.
This example summarizes the above configuration
SLX (config)# interface ethernet 0/3
SLX (conf-if-eth-0/3)# lldp disable
SLX (conf-if-eth-0/3)# exit
SLX (config-session-32)# source ethernet 0/1 destination erspan 1 source-ip 10.10.10.1
This example shows the configuration of ERSPAN mirroring from a source port channel port to a destination IP over GRE.
SLX (config)# monitor session 33
SLX (config-session-33)# source port-channel 1 destination erspan 1 source-ip 10.10.10.1
This example shows the configuration of ERSPAN mirroring from a VE (ve 1) to an specific destination IP(10.20.20.1). This traffic is directed over IP GRE tunnel with a source IP (10.10.10.1).
SLX (config)# monitor session 34
SLX (config-session-34)# source ve 1 destination erspan 1 source-ip 10.10.10.1 destination-ip 10.20.20.1
direction rx vrf vrf-for-erspan flow-based
SLX (config-session-34)# exit
This example shows the configuration of ERSPAN mirroring from a VLAN (vlan 100) to an specific destination IP(10.20.20.1). This traffic is directed over IP GRE tunnel with a source IP (10.10.10.1).
SLX (config-session-34)# source vlan 100 destination erspan 1 source-ip 10.10.10.1 destination-ip 10.20.20.1
