If the number of CRC error exceeds the configured threshold in a polling window, the configured action is taken. You can set the threshold in the range 1 to 10.
This feature is enabled by default. The default threshold is 5.device (config-sys-mon-port)# crc ? Possible completions: action Set Port CRC Monitoring Action enable Enable Port CRC Monitoring (Default: Enabled) poll-interval Set Port CRC Monitoring Poll-Interval threshold Set Port CRC Monitoring Threshold
The command crc action allows you to set various actions. The command crc poll-interval allows you to set the polling interval. The command crc threshold allows you to set the crc monitoring threshold.
The show interface status command displays the port crc status.
device# show interface status -------------------------------------------------------------------------------- Port Status Mode Speed Type Description -------------------------------------------------------------------------------- Eth 3/1 connected (up) -- 10G 10G-SFP-SR Eth 3/2 adminDown -- -- -- Eth 3/3 notconnected -- -- 10G-SFP-SR Eth 3/4 port-crcDown -- -- --
To view port crc status on a specific ethernet interface, issue the show interface ethernet command.
device# show interface ethernet 3/4
Ethernet 3/4 is port-CRC down, line protocol is down (port-crc down)
Hardware is Ethernet, address is 00e0.0c76.79e8
Current address is 00e0.0c76.79e8
Pluggable media not present
Interface index (ifindex) is 415367190
MTU 1548 bytes
10G Interface
LineSpeed Actual : Nil
LineSpeed Configured : Auto, Duplex: Full
Priority Tag disable
Last clearing of show interface counters: 13:19:17
Queueing strategy: fifo
Receive Statistics:
0 packets, 0 bytes
Unicasts: 0, Multicasts: 0, Bro
You can also view the port crc status by issuing the show ip interface brief command.
device# show ip interface brief Interface IP-Address Vrf Status Protocol ================== ========== ================== ==================== ======== Port-channel 1 unassigned administratively down down Port-channel 2 unassigned administratively down down Ethernet 3/1 10.3.1.1 default-vrf up up Ethernet 3/2 unassigned default-vrf port-crc down down Ethernet 3/3 10.3.3.1 default-vrf up down Ethernet 3/4 unassigned default-vrf administratively down down
To view the port crc status on a specific ip interface, issue the ip interface ethernet command.
device# show ip interface ethernet 3/4 Ethernet 3/4 is port-crc down protocol is down IP unassigned Proxy Arp is not Enabled Vrf : default-vrf
