This feature is applicable only for Ethernet ports.This features uses the snapshot of the ethernet port statistics maintained in the management module (MM). The statistics is updated periodically. This data is used to update the high and low water mark values. When the system is up, all the watermark values are set to zero by default.
Recording high and low water marks
This feature reads the ethernet port statistics in every 6 seconds and collects the ingress and egress MBPS and PPS. If the collected value is greater than the existing high watermark value, the high watermark value is updated with the collected value. If the value is non-zero and lower than the existing low watermark value, the low watermark value is updated with the collected value. If the value is zero, then it is ignored.
The watermark values recorded are maintained in two ways; the last 2 hours and the last two days.
The current 1 hour and 24 hour windows start when the MM is up.Resetting watermark values
The watermark values are reset on chassis reboot. If a card goes down, the values for that card is maintained just the in the way it is handled when the card is up. Whenever a new card is up, watermark feature checks if the new card type is different from the old card that was occupying the slot. If yes, the data for that particular slot is reset.
Enabling and disabling High and Low watermarks
device(config)# system interface utilization-watermark
The no form of the command disables the feature. For more details about the command, please refer the SLX-OS Command Reference guide.
By default, this feature is enabled globally.When the feature is disabled, the watermark values already recorded persist. When the feature is enabled again, all the watermark values are reset to default. The show and clear commands to display and clear watermark values are available even when the feature is disabled. When you disable the feature, the configuration shall be saved and restored on reset.
