Configuring SSL on the gRPC telemetry server
  1. In privileged EXEC mode, enter configure terminal.
    device# configure terminal
  2. Enter telemetry server, with the option of specifying a VRF other than the default mgmt-vrf.
    • (Default) mgmt-vrf
      device(config)# telemetry server
    • Other VRF
      device(config)# telemetry server use-vrf blue_vrf
  3. Enter the activate command.
    device(config-server-mgmt-vrf)# activate
  4. Enter do telemetry client-cert generate to generate SSL certificates for the server and client.
    device(config-server-mgmt-vrf)# do telemetry client-cert generate
  5. Verify the certificate is active with the do show telemetry client-cert command.
    This output displays the SSL public CA certificate that is used for secure connections on the client side for establishing SSL connections, such as streaming with recipients for gRPC clients or destinations.
    device(config-server-mgmt-vrf)# do show telemetry client-cert
    -----BEGIN CERTIFICATE-----
    MIIC2jCCAcICAQEwDQYJKoZIhvcNAQEFBQAwMzELMAkGA1UEBhMCQ0ExEDAOBgNV
    BAoMB0Jyb2NhZGUxEjAQBgNVBAMMCWxvY2FsaG9zdDAeFw0xNzAzMjExNzQ1NDNa
    Fw0xODAzMjExNzQ1NDNaMDMxCzAJBgNVBAYTAkNBMRAwDgYDVQQKDAdCcm9jYWRl
    MRIwEAYDVQQDDAlsb2NhbGhvc3QwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEK
    AoIBAQC+YG/CkiNm/BO+u1mYLKP8cpz/0O9CE+fusO0spXxjKfjPAvK7kiogxABm
    bg9MQeWl4SbFa5x3q5uyZJxApJ+tAnnWZa+cbj5pmNsQFfIbFOwSAmFyhh/NIp7Y
    /wApskKjnVsMFkarqX8W2xKxZreapZFMa9DGpOeh8Jo2yvcTAimFfSJ4nyKlCr1C
    DuuaTSvAttC8Z9mEqD9TOaSYwQI0pnfVO+ySgY8ndqDXYdRvl+bV1taghlKOgxMY
    J78lyZxYf6CIn22BAaz/f9a5ffS13Hh5Cmurj2dUmmqDE49p2KEVtXQ3D6nuopli
    V49ok+z93/40Uq4OVJZJk5Kx8ZuxAgMBAAEwDQYJKoZIhvcNAQEFBQADggEBAI1d
    1VkMH9i3SorPIHpbVqbeDe7LPdaFmrT0COr3AFUECw3gBj1Zy82Kp8XkIJJdVCu8
    MNm3wTARqeNBY2c3luw6QeA6l4qRIVM4FqNj6rvtqtNZQ9EEKRRwAm0GSVp+uSvu
    E88XSXO+r6N+SXQemRIyhNQ7LJq+cDEaP5WfNtKg+zj085Xd0qiB94BKFt5Q+xAa
    B7lwuUvT7Yt92aUVXIaZ6aY5oMv4t7+lPBBKjg8cNeywDa9h3yVZYIzSggghu0qu
    GZO57qUh5agxqKiEVf9Ya325u5gj73UJsKOSsyVA1HB8RsPEEdz8j8FBAqMNSTQj
    8UDtUGpYiYlzyiBUELc=
    -----END CERTIFICATE-----
  6. Enter transport ssl.
    device(config-server-mgmt-vrf)# transport ssl
The following example is a complete SSL configuration example.
device(config-server-mgmt-vrf)# do show telemetry server status
Telemetry Server running on IP 10.128.116.10 and port 1, with transport as tcp.
Active Sessions:
Client            Profiles Streamed                      Interval   Uptime      Last Streamed
ClientIP1/Host1   default_interface_statistics           120 sec    05/10:23    2017-01-15: :05:07:33
                  default_system_utilization_statistics  300 sec    05/10:23    2017-01-15: :05:07:33
ClientIP2/Host2   default_system_utilization_statistics  300 sec    05/10:23    2017-01-15: :05:07:33
Telemetry Server running on IP 10.128.116.10 and port 1, with transport as ssl.
Active Sessions:
