Each component can be in one of two states, down or marginal, based on factory-defined or user-configured thresholds. (The default thresholds are listed in Configuring System Monitor.)
device(config)# system-monitor fan threshold marginal-threshold 1 down-threshold 2
You can disable the monitoring of each component by setting down-threshold and marginal-threshold values to 0 (zero).
