Considerations for
SLX 9740/Extreme 8820 devices
		IPV6 ACL based Egress Mirroring is not supported due to hardware limitations across all SPAN
			types. Only four (4) hardware SPAN sessions are supported. Of the four (4) session, one
			(1) is reserved for the session created by the legacy acl-mirror command.
          These are the limitations for ERSPAN mirroring.
            -  In
            SLX 9740/Extreme 8820 if ingress and
						egress ERSPAN mirroring is configured to same ERSPAN destination, then the
						direction field in ERSPAN type 3 header will not have correct values for the
						mirrored flow.
-  ERSPAN ID cannot be set for
						port based ERSPAN due to hardware limitations.
- For ingress mirroring, copying of VLAN and
						COS field from original frame to ERSPAN type3 header of mirrored copy is
						supported for flow based ERSPAN. It is not supported for Port based ERSPAN
						and is a hardware limitation.
