Configuration Considerations before Enabling
		MPLS on a VE Interface
	  Before enabling MPLS on a VE interface, consider the configuration notes in this section.
		-  The user must create a VE
		  vid
			  virtual interface ID. The virtual interface ID is a decimal number that represents an already configured VE interface.
		-  At least one IP address must be configured over a VE interface.
		-  The user can enable MPLS on two or more tags on the same port.
		-  In the output of the show vlan  command,
				MPLS packets that are received on an MPLS enabled VE interface are displayed in the
				Bytes Received field.
