When there is not enough unallocated bandwidth on an interface to fulfill the requirements of a new LSP that has passed admission control, existing LSPs that have a lower priority may be preempted. When preemption occurs, bandwidth allocated to lower-priority LSPs is reallocated to the higher-priority LSP. LSP preemption depends on the bandwidth requirements and priority of the new LSP, compared to the bandwidth allocation and priority of already existing LSPs.
When LSP preemption is necessary, the device uses the following rules:
LSP preemption rules have changed to improve the scalability and performance for Fast Reroute (FRR) enabled LSPs. See bullets three and four below for changes to LSP preemption for FRR enabled LSPs.In the example above, bandwidth has been allocated to an LSP that has a hold priority of three and a mean-rate of 1,000 Kbps. When a new LSP with a setup priority of two, hold priority of one, and mean-rate of 10,000 Kbps is established, admission control, bandwidth allocation, and LSP preemption work as described below.
Once this happens, the reservable bandwidth array for the interface looks like this:
						 Priority  |
						 Unreserved Bandwidth  |
						 0  |
						 10,000  |
						 1  |
						 0  |
						 2  |
						 0  |
						 3  |
						 0  |
						 4  |
						 0  |
						 5  |
						 0  |
						 6  |
						 0  |
						 7  |
						 0  |
						 Active : LSP with setup 2, hold 1, mean-rate 10,000 Preempted: LSP with setup 6, hold 3, mean-rate 1,000  |
On this interface, the only LSP that could preempt the active LSP would be have a setup and hold priority of zero.
When multiple LSPs are candidates for preemption, the device normally preempts the LSP with the lowest priority. However, when preempting a higher priority LSP with a high bandwidth requirement would allow lower priority LSPs with lower bandwidth requirements to avoid preemption, the higher-priority LSP is preempted.
For example, consider an interface with 10,000 Kbps of reservable bandwidth, allocated to two active LSPs: one with a setup priority of three, hold priority of two, and mean-rate of 5,000 Kbps; and another with a setup priority of four, hold priority of three, and mean-rate of 2,500 Kbps. When an LSP with a setup priority of one, hold priority of zero, and mean-rate of 7,500 Kbps is established, the following take place.
