To configure a maximum IP packet size for an LSP, complete the following steps.
		  Enable the device for configuration.
		  Enable the MPLS router.
			 device(config)# router mpls
		  enable and configure the label switched path (LSP).
			 device(config-router-mpls)# lsp tunnel1
		  In this example, the LSP specified name is
			 tunnel1.
		  Configure the IP packet maximum transmission unit size.
			 device(config-router-mpls-lsp-tunnel1)# ipmtu 1500
			 packet-size variable specifies the maximum packet size in bytes for IP packets transiting the LSP without being fragmented.
		The following example configures a maximum IP packet size of 1500 bytes for LSP
		  tunnel1.
		device# configure terminal
