The show ip tcp vrf connections command displays information about each TCP connection on the VRF, including the local IP address, local port number, remote IP address, remote port number and the state of the connection. For example.
        device# show ip tcp vrf green connections
Local IP address:port <-> Remote IP address:port TCP state    (hdl itc cln pdn)
0.0.0.0:179 <-> 0.0.0.0:0 LISTEN (000100bf: 13, 0, 0)
Total 1 TCP connections
      Syntax: show ip tcp vrf vrf-name connections
The vrf-name parameter specifies the VRF that the user wants to display TCP connections for.
