Configuration Considerations for Enabling
		MPLS on a LAG Interface
	  When MPLS is globally enabled on the device, a port that is configured in a LAG can be enabled as an MPLS interface port to create an MPLS LAG. The user can do this through either of the following approaches:
		-  Include a primary LAG port that has already been MPLS-enabled in a new LAG
		-  MPLS-enable a primary LAG port of a previously configured LAG
	  The user must consider the following points when configuring MPLS on a LAG:
		-  MPLS configuration on dynamic lag interfaces
				are supported.
		-  MPLS is enabled on the primary port of the LAG and this enables MPLS on the entire LAG. Secondary ports of the LAG cannot be individually configured for MPLS.
