To display only the routes to a specified network, enter a command such as the following at any level of the CLI.
        device# show ip bgp vpnv4 routes 200.2.1.0/24
Route Distinguisher: 1:1
Number of BGP Routes matching display condition : 1
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
       E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH
       S:SUPPRESSED F:FILTERED s:STALE
       Prefix             Next Hop        MED        LocPrf     Weight Status
1      200.2.1.0/24       1.1.1.1          none      100        0      bI
         AS_PATH: 70
       Route is not advertised to any peers
		Syntax: show ip bgp vpnv4 routes ip-address/mask
The ip-address/mask parameter specifies a particular route. When the user also uses the optional longer-prefixes parameter, then all statistics for routes that match the specified route or have a longer prefix than the specified route are displayed. For example, when the user specifies 10.157.0.0 longer, then all routes with the prefix 10.157 or that have a longer prefix (such as 10.157.22) are displayed.
The number of BGP routes matching display conditions field in this display is described in the table below.
| This field... | Displays... |
| Number of BGP Routes matching display conditions | The number of routes to the network specified as a parameter in the show ip bgp vpnv4 routesip-addr command. |
