The following display examples come from Transit Router 3. Displays are shown for the show mpls rsvp session and show mpls rsvp session detail commands.
The display for Transit Router 3 shows a Transit Detour (DT) path. The DT path is the detour path that is an alternative to the primary path configured on Ingress Router 4 from itself to Egress Router 5. This detour path, shown from Ingress Router 4 at Loopback IP address 10.4.4.4 to Egress Router 5 at Loopback IP address 10.5.5.5, is only used when a link or router fails between the source and destination of the primary path.
device3# show mpls rsvp session
Codes: DI:Ingress Detour  DT:Transit Detour  DM:Merged Detour
       DE:Egress Detour  RP:Repaired Session
Ingress RSVP:     0 session(s)
Transit RSVP:     1 session(s)
To              From              St    Style Lbl_in Lbl_out LSPname
10.5.5.5        10.4.4.4(DT)      Up    SE    1028   1028    1
Egress RSVP:      0 session(s)
The following example displays the output from Transit Router 3 using the show mpls rsvp session detail command. This command provides additional details about the paths described in the output from the show mpls rsvp session command.
For the DT path, the "Explicit path hop count:" field shows that two hops exist from this router to the egress of the path at routers with the following at IP addresses: 10.11.11.2 (Transit Router 1) and 10.15.15.2 (Egress Router 5).
device3# show mpls rsvp session detail
  Time left in seconds (PATH refresh: 2, ttd: 141
                        RESV refresh: 25, ttd: 154)
  Tspec: peak 0 kbps rate 0 kbps size 0 bytes m 20 M 1500
  Explicit path hop count: 2
   10.11.11.2 (S) -> 10.15.15.2 (S)
  Received RRO count: 2
   Protection codes: P: Local  N: Node  B: Bandwidth  I: InUse
   10.11.11.2 -> 10.15.15.2
  PATH rcvfrom: 10.10.10.2      (e12/1         ) (MD5 OFF)
  PATH sentto:  10.11.11.2      (e11/18        ) (MD5 OFF)
  RESV rcvfrom: 10.11.11.2      (e11/18        ) (MD5 OFF)
