Specifying the Primary Path for an LSP
The user can specify a user-defined path or no path at all. Once the LSP is enabled, the ingress LER attempts to signal the other LSRs in the path so that resources can be allocated to the LSP. When the user does not specify a primary path, the path used in the LSP is the shortest path to the egress LER, as determined from standard IP routing methods, or CSPF when it is enabled.
In the following example, to specify the sf_to_sj path as the primary path for LSP tunnel1, complete the following steps.
  1. Enable the device for configuration.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable and configure the specified label switched path (LSP).
    device(config-router-mpls)# lsp tunnel1
    In this example, the specified LSP is tunnel1.
  4. Configure the primary path.
    device(config-router-mpls-lsp-tunnel1)# primary-path sf_to_sj
    In this example, the primary path is defined as sf_to_sj.
The following example configures the primary path as sf_to_sj for LSP tunnel1.
device# configure
