To configure the label withdrawal delay timer, perform the following steps.
		  In privileged EXEC mode, enter global configuration mode.
device# configure terminal
		  Enable MPLS on the device.
device(config)# router mpls
		  Access LDP configuration mode.
device(config-router-mpls)# ldp
		  Configure the delay timer.
device(config-router-mpls-ldp)# label-withdrawal-delay 100
		  In this example, the timer is set to 100 seconds. The default value is 60 seconds.
		  If you set the timer to 0 (zero), the label withdrawal delay feature is disabled for subsequent events. Any FEC which has already started the label withdrawal delay timer continues to run the timer and to delay sending its label withdrawal messages upstream.
		The following example shows the previous configuration steps.
