To display OSPF ABR and ABSR Information for a specified VRF, enter the following command at any level of the CLI.
        device# show ip ospf vrf green config
Router OSPF: Enabled
Redistribution: Enabled
Default OSPF Metric: 10
OSPF Auto-cost Reference Bandwidth: Disabled
OSPF Redistribution Metric: Type2
OSPF External LSA Limit: 14447047
OSPF Database Overflow Interval: 0
RFC 1583 Compatibility: Enabled
Router id: 192.168.201.1
Interface State Change Trap:                      Enabled
Virtual Interface State Change Trap:              Enabled
Neighbor State Change Trap:                       Enabled
Virtual Neighbor State Change Trap:               Enabled
Interface Configuration Error Trap:               Enabled
Virtual Interface Configuration Error Trap:       Enabled
Interface Authentication Failure Trap:            Enabled
Virtual Interface Authentication Failure Trap:    Enabled
Interface Receive Bad Packet Trap:                Enabled
Virtual Interface Receive Bad Packet Trap:        Enabled
Interface Retransmit Packet Trap:                 Disabled
Virtual Interface Retransmit Packet Trap:         Disabled
Originate LSA Trap:                               Disabled
Originate MaxAge LSA Trap:                        Disabled
Link State Database Overflow Trap:                Disabled
Link State Database Approaching Overflow Trap:    Disabled
OSPF Area currently defined:
Area-ID          Area-Type Cost
0                normal    0
1                normal    0
      Syntax: show ip ospf vrf vrf-name config
The vrf-name parameter specifies the VRF that the user wants to display general OSPF configuration information for.
