Configuring the threshold-table for adjustment threshold
Use the autobw-threshold-table command at the MPLS configuration level to begin configuration of the table. This command leads to a new parser mode config-mpls-autobw-threshold-table. Under this mode, commands to remove and add a row in the table is provided.
To set the adjustment-threshold table, complete the following steps.
  1. Enable the device for configuration.
    device>configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable the auto-bandwidth threshold table.
    device(config-router-mpls)# autobw-threshold-table
  4. Configure the auto-bandwidth threshold table.
    device(config-mpls-autobw-threshold-table)# bandwidth-ceiling 10 threshold 2000
    device(config-mpls-autobw-threshold-table)# bandwidth-ceiling 1000 threshold 3000
    device(config-mpls-autobw-threshold-table)# bandwidth-ceiling 10000 threshold 5000
  5. Note
    The user is also required to set the default scenario. The case from the last threshold configured to maximum bandwidth value. If the user does not set this values, the threshold value for the maximum (previous) range is used.
    Configure the default. In this example, the default is configured to 10%.
    device(config-mpls-autobw-threshold-table)# bandwidth-ceiling max threshold percentage 10
    -or-
    device(config-mpls-autobw-threshold-table)# bandwidth-ceiling max threshold 10000
The following example combines the steps above to configure the adjustment-threshold table.
device>configure
-or-
Removing threshold entries
To remove one of the threshold entries, complete the following steps.
    device>configure
  4. Remove the threshold entry by using the no form of the command.
    device(config-mpls-autobw-threshold-table)#no bandwidth-ceiling 1000 threshold 3000
The following example combines the steps above to remove one of the threshold entries.
device>configure
Clearing the threshold table
To clear the threshold table, complete the following steps.
    device>configure
  3. Clear the threshold table using the no form of the command.
    device(config-mpls)# no autobw-threshold-table
    The table is cleared with this command. If the LSP or template is set to use the global table, the adjustment-threshold considered would be zero (0) (default).
The following example combines the steps above to clear the threshold table.
device>configure
Configuring an auto-bandwidth template to use the global table for adjustment threshold.
To configure an auto-bandwidth template to use the global table for adjustment threshold, complete the following steps.
    device>configure
  3. Enable the auto-bandwidth template. In this example, template 1 is selected.
    device(config-mpls)# autobw-template template1
  4. Enable the global table.
    device(config-mpls-autobw-template-template1)# adjustment-threshold use-threshold-table
The following example combines the steps above to configure auto-bandwidth template 1 to use the global table for adjustment threshold.
device>configure
Configuring an LSP to use the global table for adjustment threshold
To configure an LSP to use the global table for adjustment threshold, complete the following steps.
    device>configure
  3. Select and enable LSP. In this example LSP1 is selected.
    device(config-mpls)# lsp lsp1
  4. Enable auto-bandwidth.
    device(config-mpls-lsp-lsp1)# autobw
  5. Configure the adjustment threshold to use the threshold table.
    device(config-mpls-lsp-lsp1-autobw)# adjustment-threshold use-threshold-table
the following example combines the steps above to to configure an LSP1 to use the global table for adjustment threshold.
device>configure
Configure the LSP or template to use percentage values.
To configure the LSP to use the percentage values, complete the following steps
    device>configure
  5. Configure the adjustment threshold to use the percentage values.
    The user issues the same command with the no option. The LSP now uses the percentage threshold.
    device(config-mpls-lsp-lsp1-autobw)# no adjustment-threshold use-threshold-table
The following example combines the steps above to configure the LSP to use the percentage values.
