To change the global link and target intervals for LDP Hello messages, and configure a link interval for an interface, perform the following steps.
		  In privileged EXEC mode, enter global configuration mode.
device# configure terminal
		  Enable MPLS on the device.
device(config)# router mpls
		  Access LDP configuration mode.
device(config-router-mpls)# ldp
		  Change the interval for the link sessions.
device(config-router-mpls-ldp)# hello-interval-link 10
		  In this example, the hello interval set to 10. The default value is 5. You can enter an integer from 1 through 32767.
The Hello interval for link sessions can be overridden on a per-interface basis.
		  Change the interval for the target sessions.
device(config-router-mpls-ldp)# hello-interval-target 20
		  In this example, the hello interval set to 20. The default value is 15. You can enter an integer from 1 through 32767. The change takes effect immediately.
 This value can only be set globally for all targeted LDP sessions on the router. Per-interface configuration is only available for Link LDP sessions.
		  Access MPLS mode.
device(config-router-mpls-ldp)# exit
		  Enable MPLS on an interface.
device(config-router-mpls)# mpls-interface ethernet 0/2
		  For example, MPLS is enabled on interface
					on Ethernet port 0/2.
		  Configure LDP parameters on the interface.
device(config-router-mpls-interface-0/2)# ldp-params
		  Change the interval for link sessions on the interface.
device(config-router-mpls-interface-0/2-ldp-params)# hello-interval 15
		  In this example, the hello interval set on this interface for LDP Link Hello messages is set to 15 seconds. You can enter an integer from 1 through 65535. No default value exists for this parameter. However, when no value is set for this parameter, it defaults to the global LDP Hello interval. When you set a hello interval on the interface, it overrides the global LDP Hello interval.
		The following example shows the previous steps to configure the LDP Hello interval.
