The following task shows the steps required for enabling BGP on a CE device and assigning a PE device as a BGP neighbor. For an example of a full configuration required to exchange routes in an external BGP (EBGP) network, see the EBGP for route exchange task.
		  On a CE device, enter the
			 configure terminal command.
			 device# configure terminal
		  Enter the
			 router bgp command to enable BGP routing.
			 device(config)# router bgp
		  Enter the
			 local-as command to configure the AS number.
			 device(config-bgp)# local-as 2
		  Configure a PE BGP neighbor using the
			 neighbor remote-as command.
			 device(config-bgp)# neighbor 10.33.33.3 remote-as 1
		The following example enables BGP on a CE and assigns a PE as a BGP neighbor.
