Use the
		max-bypasses command to set the maximum number of dynamic bypass LSPs the user can create for this MPLS interface. This is the limit for the total number of dynamic bypass LSPs the user can create for this protected MPLS interface. When there is no configuration for this parameter under the interface mode, the global
		max-bypasses parameter value is considered for this parameter. This parameter value must be less than the globally set
		max-bypasses value.
		To set the maximum number of dynamic bypasses per interface, complete the following steps.
		  Enable the device for configuration.
		  Enable the MPLS router.
			 device(config)# router mpls
				Enable MPLS-capable interfaces
					and specify the selected interface. In this example, the selected Ethernet
					interface is 0/8 .
					device(config-router-mpls)# mpls-interface ethernet 0/8
		  Enable the interface level dynamic bypass.
			 device(config-router-mpls-if-ethernet-0/8)# dynamic-bypass
		  Configure the dynamic bypass maximum bypasses. In this example, the configuration for the maximum number of bypasses is five (5
			 device(config-router-mpls-if-ethernet-0/8-dynamic-bypass)# max-bypasses 5
		The following example combines the steps above
				to set the maximum number of dynamic bypasses for Ethernet interface 0/8  to
				five 5
		device>configure
