The route-attribute entries table lists the sets of BGP VPNv4/VPNv6 attributes stored in the device memory. Each set of attributes is unique and can be associated with one or more routes. In fact, the device typically has fewer route attribute entries than routes. To display the route-attribute entries table at any level of the CLI.
      device# show ip bgp vpn attribute-entries
        Total number of BGP Attribute Entries: 55
1       Next Hop  :0.0.0.0            Metric   :0               Origin:IGP
        Originator:0.0.0.0            Cluster List:None
        Aggregator:AS Number :0      Router-ID:0.0.0.0          Atomic:None
        Local Pref:100               Communities:Internet
        Extended Community: RT 600:1
        AS Path   :310
        Address: 0x24644060  Hash:45 (0x0100036e) Reference Counts: 0:0:30
2       Next Hop  :0.0.0.0            Metric   :0               Origin:IGP
        AS Path   :311
        Address: 0x24645f48  Hash:47 (0x01000370) Reference Counts: 0:0:30
3       Next Hop  :2.2.2.2            Metric   :0               Origin:IGP
        Extended Community: RT 100:1 RT 200:1
        AS Path   :206 311
        Address: 0x24645538  Hash:276 (0x0100087a) Reference Counts: 30:0:0
	 This display shows the following information.
				 This field...  |
				 Displays...  |
				 Total number of BGP Attribute Entries  |
				 The number of routes contained in the BGP4 route table for this device.  |
				 Next Hop  |
				 The IP address of the next hop device for routes that have this set of attributes.  |
				 Metric  |
				 The cost of the routes that have this set of attributes.  |
				 Origin  |
				 The source of the route information. The origin can be one of the following:
 When BGP4 compares multiple routes to a destination to select the best route, IGP is preferred over EGP and both are preferred over INCOMPLETE.  |
				 Originator  |
				 The originator of the route in a route reflector environment.  |
				 Cluster List  |
				 The route-reflector clusters through which this set of attributes has passed.  |
				 Aggregator  |
				 Aggregator information:
 Router-ID shows the device that originated this aggregator  |
				 Atomic  |
				 Whether the network information in this set of attributes has been aggregated and this aggregation has resulted in information loss.
 Note: Information loss under these circumstances is a normal part of BGP4 and does not indicate an error.
				 Local Pref  |
				 The degree of preference for routes that use this set of attributes relative to other routes in the local AS.  |
				 Communities  |
				 The communities that routes with this set of attributes are in.  |
				 Extended Community  |
				 The extended community attributes.  |
				 AS Path  |
				 The ASs through which routes with this set of attributes have passed. The local AS is shown in parentheses.  |
				 Address  |
				 This is an internal value used for debugging purposes only.  |
				 Hash  |
				 Reference Counts  |
