LSR restarting procedure
	  After an LSR restarts its LDP components, when its MPLS forwarding state is not preserved as in the case of the routers in helper-only mode, it sends out the FT TLV with Recovery Time set to 0 in the LDP Initialization message to its neighbor.
	  When the MPLS forwarding state has been preserved across the restart, the LSR does the following:
		- Start the Forwarding State Holding timer.
		-  Mark all the MPLS forwarding entries as stale.
		-  Set the Recovery Time to the current value of the Forwarding State Holding timer when it sends out LDP Initialization message to its neighbor.
			 - When the timer has not expired, the LSR uses the labels and next-hop information received from the neighbor to look up and clear the stale flag for the corresponding label-FEC entries.
			 - When the timer has expired, all the entries that are still marked as stale are deleted and the LDP GR procedure is completed.
