Configuring RSVP Message Authentication on an MPLS VE Interface
Complete the following steps to configure RSVP message authentication for MPLS interface ve 100.
  1. Configure the device.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Specify MPLS-capable Virtual Ethernet (VE) interface.
    device(config-router-mpls)# mpls-interface ve 100
    In this example, VE interface 100 is selected.
  4. device(config-router-mpls-if-ve-100)# rsvp
  5. Configure RSVP message authentication for MPLS interface ve 100.
    device(config-router-mpls-if-ve-100-rsvp)# authentication key private
    in this example, the variable private specifies a text string of up to 64 characters that is encrypted and used for RSVP message authentication.
The following example configures RSVP message authentication using MD5 for a MPLS VE interface.
device# configure
