A bypass LSP CSPF computation can use tie breaking options when there are multiple equal cost paths with equal hops. The tie breaking option can be random, most fill, or least fill. The use can configure these options using the
		tie-breaking command. Consider the
		random option as the default option. This parameter is an adaptive parameter.
		  Enable the device for configuration.
		  Enable the MPLS router.
			 device(config)# router mpls
		  Configure the bypass LSP with the unique static bypass LSP name of
			 my-bypass-lsp
			 device(config-router-mpls)# bypass-lsp my-bypass-lsp
		  Configure the
			 tie-breaking command with one of the following choices.
	  The following example combines the steps above to configure a static bypass LSP with a unique bypass LSP name of
my-bypass-lsp
		 and a choice of three different
 tie-breaking command options.
device>configure
device(config-router-mpls-bypass-lsp-my-bypass-lsp)# tie-breaking random
-or-
device(config-router-mpls-bypass-lsp-my-bypass-lsp)# tie-breaking most-fill
-or-
device(config-router-mpls-bypass-lsp-my-bypass-lsp)# tie-breaking least-fill
