Configuring bandwidth for a MPLS fast reroute
To define a bandwidth constraint for the fast reroute path, complete the following steps.
  1. Enable the device for configuration.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Configure the LSP.
    device(config-router-mpls)# lsp frr_tunnel
    In this example, the LSP name is frr_tunnel .
  4. Enable configuration of fast reroute options.
    device(config-router-mpls-lsp-frr_tunnel)# frr
  5. Configure the bandwidth for the backup LSP.
    device(config-router-mpls-lsp-frr_tunnel-frr)# bandwidth 100
    In this example, the bandwidth is configured 100 kbits/sec. for the backup LSP. The acceptable value can be between zero (0) and two (2) Gbps, with 0 being the default value.
The example below defines a bandwidth of 100 kbits/sec. for the fast reroute path.
device# configure
An additional way to add bandwidth to a FRR path is by using the bandwidth inherit command.
