Global revertiveness configuration
Complete the following steps to configure global revertiveness.
  1. Configure the device.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable to configure policy parameters.
    device(config-router-mpls)# policy
  4. Set the LSPs connect maximum number of retries.
    device(config-router-mpls-policy)# retry-limit 20
    In this example, the maximum number of retries is set to 20.
  5. Exit the current level.
    device(config-router-mpls-policy)# exit
  6. Set the signaled label switched path (LSP).
    device(config-router-mpls)# lsp t1
    In this example, the LSPs name is "t1".
  7. Enable the LSP to be modified without disabling the LSP.
    device(config-router-mpls-lsp-t1)# adaptive
  8. Enable for fast reroute options.
    device(config-router-mpls-lsp-t1)# frr
  9. Configure the revertive hold time for the LSP.
    device(config-router-mpls-lsp-t1-frr)# revertive holdtime 20
    In this example, the revertive hold time is set to 20.
  10. Exit from the current level.
    device(config-routr-mpls-lsp-t1-frr)# exit
  11. Apply the parameter modifications to the LSP.
    device(config-router-mpls-lsp-t1)# commit
The following example show the how the global revertiveness is enabled by default in the fast reroute mode for an adaptive LSP.
device# configure
device(config-router-mpls-lsp-t1-frr)# exit
