To view the route table for a specified VPNv4 neighbor, enter the following command.
      device# show ip bgp vpnv4 neighbor 10.10.2.3 routes-summary
1   IP Address: 10.10.2.3
Routes Accepted/Installed:30,  Filtered/Kept:0,  Filtered:0
   Routes Selected as BEST Routes:30
      BEST Routes not Installed in IP Forwarding Table:0
   Unreachable Routes (no IGP Route for NEXTHOP):0
   History Routes:0
NLRIs Received in Update Message:30,  Withdraws:0 (0),  Replacements:0
   NLRIs Discarded due to
      Maximum Prefix Limit:0, AS Loop:0
      Invalid Nexthop:0, Invalid Nexthop Address:0.0.0.0
      Duplicated Originator_ID:0, Cluster_ID:0
Routes Advertised:154,  To be Sent:0,  To be Withdrawn:0
NLRIs Sent in Update Message:154,  Withdraws:0,  Replacements:0
Peer Out of Memory Count for:
   Receiving Update Messages:0, Accepting Routes(NLRI):0
   Attributes:0, Outbound Routes(RIB-out):0 Outbound Routes Holder:0
	 This display shows the following information.
				 This field...  |
				 Displays...  |
				 Routes Accepted or Installed  |
				 How many routes the has received from the neighbor during the current BGP4 session:
				 Routes Selected as BEST Routes  |
				 The number of routes that the device selected as the best routes to their destinations.  |
				 BEST Routes not Installed in IP Forwarding Table  |
				 The number of routes received from the neighbor that are the best BGP4 routes to their destinations, but were nonetheless not installed in the IP route table because the device received better routes from other sources (such as OSPF, RIP, or static IP routes).  |
				 Unreachable Routes  |
				 The number of routes received from the neighbor that are unreachable because the device does not have a valid RIP, OSPF, or static route to the next hop.  |
				 History Routes  |
				 The number of routes that are down but are being retained for route flap dampening purposes.  |
				 NLRIs Received in Update Message  |
				 The number of routes received in Network Layer Reachability (NLRI) format in UPDATE messages:
				 NLRIs Discarded due to  |
				 Indicates the number of times the device discarded an NLRI for the neighbor due to the following reasons:
				 Routes Advertised  |
				 The number of routes the device has advertised to this neighbor:
				 NLRIs Sent in Update Message  |
				 The number of NLRIs for new routes the has sent to this neighbor in UPDATE messages:
				 Peer Out of Memory Count for  |
				 Statistics for the times the device has run out of BGP4 memory for the neighbor during the current BGP4 session:
