Extreme Networks devices support MPLS over virtual ethernet (VE) interfaces. MPLS over VE interfaces enables MPLS to be configured over tagged links. With this feature, MPLS can run over a single tag on the port. Other tags on the port can be used for other applications, such as Layer 2 VLANs, VPLS endpoints, and VLL endpoints.
An MPLS enabled VE interface supports the following services.
Multi-port static ARP configuration in not supported for MPLS uplinks.
