Configure Redistribute Attribute on Tenant VRF
EFA allows provisioning of redistribute attribute per tenant VRF during VRF create and VRF update operations.
VRF is updated on the switches during the user triggered VRF update operation based on the endpoints present in the endpoint groups using the VRF.
  • Default value of redistribute is connected.
  • Choosing specific devices for redistribute provisioning is not allowed.
  1. To configure redistribute attribute when you create a tenant VRF, run the following commands:
    # efa tenant vrf create --name <vrf-name> --tenant <tenant-name> --redistribute <list>
  2. To configure redistribute attribute on an existing tenant VRF, run the following commands:
    # efa tenant vrf update --name <vrf-name> --tenant <tenant-name> --operation <redistribute-add|redistribute-delete> --redistribute <static | connected>
    # efa tenant vrf create --name vrf1 --tenant tenant1 --redistribute static
    # efa tenant vrf create –name vrf10 –tenant tenant1
    # efa tenant epg create --name ten1epg1 --tenant tenant1 --port10.24.80.134[0/11],10.24.80.135[0/11] --switchport-mode trunk –ctag-range 11 --vrf vrf1 –-anycast-ip 11:10.10.11.1/24
    # efa tenant epg create --name ten1epg2 --tenant tenant1 --port10.24.80.134[0/12],10.24.80.135[0/12] --switchport-mode trunk -–ctag-range 12 --vrf vrf10 -–anycast-ip 12:10.10.12.1/24
    # efa tenant vrf update -–name vrf10 –tenant tenant1 --operation redistribute-add --redistribute static
    Device1# sh run router bgp
    router bgp
    local-as 4200000000
    address-family ipv4unicast vrf vrf1
    redistribute static
    address-family ipv4unicast vrf vrf10
    redistribute connected
    redistribute static
    Device2# sh run router bgp
    router bgp
    local-as 4200000000
    redistribute static
    redistribute static
    address-family ipv6unicast vrf vrf1
    redistribute static
    !address-family ipv6unicast vrf vrf10
    redistribute static
