Use this procedure to change the
        default gateway of a TPVM. This procedure has no impact on the functioning of EFA
        high-availability mode.
                - The gateway IP address must be in the same subnet as one of the subinterfaces
                    that are created in EFA.
- Perform this procedure on both
                    nodes where EFA is deployed, to avoid a loss of EFA functionality.
- Perform this procedure with
                    caution. EFA and SLX-OS do not validate reachability of the gateway during this
                    operation.
- Vital services, such as DNS, NTP, and LDAP, must be reachable from the new
                    gateway.
                Add static IP addresses to the
                    subinterface.
                You can assign a maximum of one
                    pair of static IP addresses. Only one subinterface at a time can have static IP
                    addresses.
                    efa mgmt subinterface staticip --name <sub-int-name> --ip1 <ip-addr>
--ip2 <ip-addr>
                Change the gateway of the
                    standby TPVM.
                    efa inventory device execute-cli --ip <standby-slx-ipaddr>
--command "tpvm TPVM,interface management ip <standby-tpvm-ipaddr>
gw <new-gateway-ipaddr>" --config
                Change the gateway of the active
                    TPVM.
                    efa inventory device execute-cli --ip <active-slx-ipaddr>
--command "tpvm TPVM,interface management ip <active-tpvm-ipaddr>
