To enable external connectivity, you can configure the default-originate attribute when you create or update BGP peer (IPv4 and IPv6).
By default, default-originate is disabled.
efa tenant service bgp peer create --name <bgp-peer-name> --tenant <tenant-name>
--ipv4-uc-nbr <device-ip,vrf-name:neighbor-ip,remote-asn>
--ipv4-uc-nbr-bfd <device-ip,vrf-name:neighbor-ip,true|false>
--ipv4-uc-nbr-default-originate <device-ip,vrf-name:neighbor-ip,true/false>
--ipv4-uc-nbr-default-originate-route-map <device-ip,vrf-name:neighbor-ip,route-map>
efa tenant service bgp peer update --name <bgp-peer-name> --tenant <tenant-name>
--operation peer-add
Theipv4-uc-nbr-default-originate-route-map attribute
is an optional attribute.efa tenant service bgp peer create --name ten1bgppeer1 --tenant tenant11 --ipv4-uc-nbr 10.20.246.3,v1:10.20.30.40,50000 --ipv4-uc-nbr-bfd 10.20.246.3,v1:10.20.30.40,true --ipv4-uc-nbr-default-originate 10.20.246.3,v1:10.20.30.40,true --ipv4-uc-nbr 10.20.246.4,v1:10.20.30.40,50000 --ipv4-uc-nbr-bfd 10.20.246.4,v1:10.20.30.40,true --ipv4-uc-nbr-default-originate 10.20.246.4,v1:10.20.30.40,true --ipv4-uc-nbr-default-originate-route-map 10.20.246.4,v1:10.20.30.40,rmap1
§efa tenant service bgp peer-group show
--detail
Name : ten1bgppeer1 Tenant : tenant11 State : bgp-peer-created Description : Static Peer ----------- Device IP : 10.20.246.4 VRF : v1 AFI : ipv4 SAFI : unicast Remote IP : 10.20.30.40 Remote ASN : 50000 Next Hop Self : false Update Source IP : BFD Enabled : true BFD Interval : 0 BFD Rx : 0 BFD Multiplier : 0 MD5 Password : Remove Private AS : false Default Originate : true Default Originate Route Map : rmap1 Prefix List In : Prefix List Out : Route Map In : Route Map Out : Dev State : provisioned App State : cfg-in-sync |
Device IP : 10.20.246.4 VRF : v1 AFI : ipv4 SAFI : unicast Remote IP : 10.20.30.50 Remote ASN : 50000 Next Hop Self : false Update Source IP : BFD Enabled : true BFD Interval : 0 BFD Rx : 0 BFD Multiplier : 0 MD5 Password : Remove Private AS : false Default Originate : false Default Originate Route Map : Prefix List In : Prefix List Out : Route Map In : Route Map Out : Dev State : provisioned App State : cfg-in-sync Device IP : 10.20.246.3 VRF : v1 AFI : ipv4 SAFI : unicast Remote IP : 10.20.30.40 Remote ASN : 50000 Next Hop Self : false Update Source IP : BFD Enabled : true BFD Interval : 0 BFD Rx : 0 |
BFD Multiplier : 0 MD5 Password : Remove Private AS : false Default Originate : true Default Originate Route Map : Prefix List In : Prefix List Out : Route Map In : Route Map Out : Dev State : provisioned App State : cfg-in-sync Device IP : 10.20.246.3 VRF : v1 AFI : ipv4 SAFI : unicast Remote IP : 10.20.30.50 Remote ASN : 50000 Next Hop Self : false Update Source IP : BFD Enabled : true BFD Interval : 0 BFD Rx : 0 BFD Multiplier : 0 MD5 Password : Remove Private AS : false Default Originate : true Default Originate Route Map : tt Prefix List In : Prefix List Out : Route Map In : Route Map Out : Dev State : provisioned App State : cfg-in-sync |
efa tenant service bgp peer show --detail
Tenant : tenant11
Description :
Static Peer
VRF : v1
AFI : ipv4
SAFI : unicast
Remote ASN : 50000
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
MD5 Password :
Prefix List In :
Prefix List Out :
Route Map In :
Route Map Out :
VRF : v1
AFI : ipv4
SAFI : unicast
Remote ASN : 50000
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
MD5 Password :
Prefix List In :
Prefix List Out :
Route Map In :
Route Map Out :
10.20.246.3SLX# show running-config router bgp address-family ipv4 unicast vrf v1 redistribute connected neighbor 10.20.30.40 remote-as 50000 neighbor 10.20.30.40 default-originate neighbor 10.20.30.40 bfd neighbor 10.40.40.252 remote-as 4200000000 neighbor 10.40.40.252 next-hop-self maximum-paths 8 ! |
10.20.246.4SLX# show running-config router bgp address-family ipv4 unicast vrf v1 redistribute connected neighbor 10.20.30.40 remote-as 50000 neighbor 10.20.30.40 default-originate route-map rmap1 neighbor 10.20.30.40 bfd neighbor 10.40.40.253 remote-as 4200000000 neighbor 10.40.40.253 next-hop-self maximum-paths 8 ! |
For information about commands and supported parameters to configure default-originate attribute, see Extreme Fabric Automation Command Reference, 3.0.0 .
