The layer3-extension is enabled by default for the Distributed VRF instantiated by EFA and you cannot disable it. The layer3-extension is disabled by default for the Centralized VRF instantiated by EFA and you cannot enable it.
When the layer3-extension is enabled, the following configurations are pushed by EFA:
efa tenant vrf create --tenant <tenant-name> --name <vrf-name>
                      --layer3-extension-enable {true | false}
efa tenant vrf create --tenant "t1" --name "v1" --routing-type "distributed" --rt-type import --rt 101:101 --rt-type export --rt 101:101
efa tenant vrf show --name v1 --tenant t1 –detail
Tenant:                     : t1
Routing Type                : distributed
Centralized Routers         :
Enable Layer3 Extension     : true
Redistribute                : connected
Max Path                    : 8
Local Asn                   :
L3VNI                       :
EVPN IRB BD                 :
EVPN IRB VE                 :
BR VNI                      :
BR BD                       :
BR VE                       :
RH Max Path                 :
Enable RH ECMP              : false
Enable Graceful Restart     : false
Route Target                :
Static Route                :
Static Route BFD            :
Network Route Address       :
Static Network              :
Aggregate Address           :
VRF Type                    :
State                       : vrf-created
Dev State                   : not-provisioned
App State                   : cfg-ready
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v1 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant                      : t1
Max Path                    : 8
Local Asn                   :
L3VNI                       : 10111
EVPN IRB BD                 : 4096
EVPN IRB VE                 : 8192
BR VNI                      : 10110
BR BD                       : 4095
BR VE                       : 8191
RH Max Path                 :
Route Target                : import 101:101
                            : export 101:101
Static Route		   :
Static Route BFD            :
Static Network		 :
Aggregate Address           :
VRF Type                    :
State                       : vrf-device-created
Dev State                   : provisioned
App State                   : cfg-in-sync
                | Rack1-Device1# show running-config vrf v1 vrf v1 rd 172.31.254.19:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! | Rack1-Device2# show running-config vrf v1 vrf v1 rd 172.31.254.20:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
efa tenant vrf create --tenant "t1" --name "v2" --routing-type "centralized"
efa tenant vrf show --name v2 --tenant t1 –detail
Tenant                    : t1
Routing Type              : centralized
Centralized Routers       : 10.20.246.15
                          : 10.20.246.16
Enable Layer3 Extension   : false
Max Path                  : 8
Local Asn                 :
L3VNI                     :
EVPN IRB BD               :
EVPN IRB VE               :
BR VNI                    :
BR BD                     :
BR VE                     :
RH Max Path               :
Route Target              :
Static Route              :
Static Route BFD          :
Static Network            :
Aggregate Address         :
VRF Type                  :
State                     : vrf-created
Dev State                 : not-provisioned|
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v2 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant                     : t1
                           : 10.20.246.16
Max Path                   : 8
Local Asn                  :
L3VNI                      :
EVPN IRB BD                :
EVPN IRB VE                :
BR VNI                     : 10110
BR BD                      : 4096
BR VE                      : 8192
RH Max Path                :
                           : export 101:101
Static Route		  :
Static Route BFD           :
Static Network		:
Aggregate Address          :
VRF Type                   :
efa tenant vrf create --tenant "t1" --name "v3" --routing-type "centralized" –-layer3-extension-enable true
efa tenant vrf show --name v3 --tenant t1 –detail
Tenant                    : t1
                          : 10.20.246.16
Max Path                  : 8
Local Asn                 :
L3VNI                     :
EVPN IRB BD               :
EVPN IRB VE               :
BR VNI                    :
BR BD                     :
BR VE                     :
RH Max Path               :
Route Target              :
Static Route              :
Static Route BFD          :
Static Network            :
Aggregate Address         :
VRF Type                  :
State                     : vrf-created
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v3 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant                    : t1
                          : 10.20.246.16
Max Path                  : 8
Local Asn                 :
L3VNI                     : 10111
EVPN IRB BD               : 4096
EVPN IRB VE               : 8192
BR VNI                    : 10110
BR BD                     : 4095
BR VE                     : 8191
RH Max Path               :
                          : export 101:101
Static Route              :
Static Route BFD          :
Static Network            :
Aggregate Address         :
VRF Type                  :
                | Rack1-Device1# show running-config vrf v3 vrf v2 rd 172.31.254.19:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! | Rack1-Device2# show running-config vrf v3 vrf v2 rd 172.31.254.20:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
