The 5-stage topology has three layers of
devices: leaf, spine, and super-spine.
You can build a 5-stage Clos from top to
bottom or bottom to top. The following example builds from top to bottom.
5-Stage Clos fabric
topology
Tip
If any devices in
a fabric are in "admin-down" state, use of the following commands in that same
fabric will not add or delete devices in the fabric: efa fabric device
add-bulk and efa fabric device remove.
Create the fabric.
efa fabric create
Add a device to the
fabric.
efa fabric device add
A device must be registered with the Inventory Service before you can add it to a fabric.
However, if you provide a user name and password when you run the command,
then the devices are automatically registered with the Inventory Service.
See the examples at the end of this procedure.
You can add multiple devices by using the efa fabric device add-bulk
command. If you choose to add multiple devices in bulk, ensure you perform
the following operations first:
Run the efa inventory
device register --ip <list-of-device-ips>
command.
device interface list --ip <device-ip> command.
In the output of the command, verify that the states of the port
links are as you expected (in the Admin Status and Oper Status
fields). If not, manually check the physical cabling and fix any
issues. Then continue with the efa fabric device
add-bulk operation.
Configure the fabric.
efa fabric configure
Topology validation occurs
during the addition of a device and during fabric configuration. The following
validations are performed:
Leaf nodes must connect
to all the spine nodes.
A spine node must connect
to all the leaf nodes.
A border leaf node connects to all the
spine nodes.
A spine node connects to all the border
leaf nodes.
No more than two leaf
nodes connect to each other.
No more than two border leaf nodes connect
to each other.
Border leaf node and leaf
node are not connected to each other.
Spine nodes are not
Super-spine nodes are not
A leaf node marked as
"multi-homed" must have an MCT neighbor.
"single-homed" is not connected to other leaf nodes.
A border leaf node marked as "multi-homed"
A border leaf node marked as "single-homed"
is not connected to other border leaf nodes.
Device role (such as leaf, border-leaf,
spine, and super-spine) is validated for a given device platform type
(for example, SLX 9840 cannot be added as a leaf).
Tip
The
validation process reports any errors as a response to the efa fabric device
add or efa fabric configure operations. You can use the efa fabric error
show command to export these errors to a CSV file.
