Log directories vary by deployment type and by application.
journalctl
					log of Keepalived for the past day. This information is useful for helping debug
					failovers, double faults, and gateway connectivity. In multi-node, high availability deployments, logs are replicated on all nodes in the cluster.
The efa system supportsave script gathers all logs, database dumps, pod logs, deployment details, and system support-save and then compresses them into a ZIP folder. You can share this ZIP folder with Extreme support personnel when troubleshooting an issue.
