Starting in EFA v2.5.0, in addition to fabric and tenant service configurations, the following asset service configurations are persisted and included in Drift and Reconcile (DRC).
The following table captures the various attributes of interface for which DRC and idempotency is supported.
Clean up explicitly any conflicting configuration which could cause reconciliation of device to fail. For example, if EFA configures a port as breakout and if that configuration is drifted by adding Layer 3 configuration to a parent interface, the reconciliation fails. It is recommended to explicitly remove the conflicting configuration from the device through the SLX CLI and retry the DRC process.| Field | Identify Drift | Reconcile configuration | Idempotency |
| Admin-state | Yes | Yes | Yes |
| Breakout mode | Yes | Yes | No |
| Speed | Yes | Yes | Yes |
| Layer-2 MTU | Yes | Yes | Yes |
| IPv4 MTU | Yes | Yes | Yes |
| IPv6 MTU | Yes | Yes | Yes |
| FEC mode | Yes | Yes | Yes |
| Link error disable | Yes | Yes | Yes |
| Toggle-threshold | Yes | Yes | Yes |
| Sampling time | Yes | Yes | Yes |
| Wait time | Yes | Yes | Yes |
| RME enable | Yes | Yes | Yes |
efa inventory device
interface redundant-managementefa inventory device
interface set-fecefa inventory device
interface set-link-error-disableefa inventory device
interface unset-fecefa inventory device
interface unset-link-error-disableFor more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
setting update --prefix-independent-convergenceefa inventory device setting update
--prefix-independent-convergence-staticefa inventory device
setting update --maximum-load-sharing-pathsefa inventory device
settings update --mct-bring-up-delayefa inventory device
settings update --maint-mode-convergence-timeFor more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
Device Reload
The device reload command allows the user to reload a device. Users can provide IPs and fabric name separated by commas. All devices in a fabric will be reloaded for any given fabric name in the command.
efa inventory device reload
Drift and reconcile and idempotency configuration support is not applicable for device reload attribute.For more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
Clear IP Route
The clear IP route command allows the user to clear a device's IPv4 and IPv6 routes. Users have the option to either clear an IPv4 or an IPv6 route.
clear route-all
Drift and reconcile and idempotency configuration support is not applicable for clear IP route attribute.For more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
SNMP Configuration
The following tables capture the various attributes of SNMP and NTP for which DRC and idempotency are supported.
Regarding idempotency for creating an entry which already exists in EFA, an error message is returned stating that the user already exists.| Field | Identify Drift | Reconcile Configuration | Idempotency | Notes |
| Community deleted | Yes | Yes | No | A valid error message is shown when a non-existent community is deleted |
| Group name associated with community is modified | Yes | Yes | Not Applicable | |
| Group deleted | Yes | Yes | Not Applicable | |
| Modify group version | No | No | Not Applicable | SLX does not support editing the SNMP group version |
| Modify read review or write view or notify view associated with group | Yes | Yes | Not Applicable | |
| Modify group name associated with SNMP user | Yes | Yes | Not Applicable | |
| Modify authentication protocol associated with SNMP user | Yes | Yes | Not Applicable | |
| Modify authentication password associated with SNMP user | Yes | Yes | Not Applicable | |
| Modify privacy protocol associated with SNMP user | Yes | Yes | Not Applicable | |
| Modify privacy password associated with SNMP user | Yes | Yes | Not Applicable | |
| Delete SNMP user | Yes | Yes | No | A valid error message is shown when a non-existent user is deleted |
| Modify encrypted keyword associated with SNMP user | Yes | Yes | Not Applicable | |
| Modify authentication type associated with group, that is, auth, noauth, notify | Yes | Yes | Not Applicable | |
| Delete SNMP host entry | Yes | Yes | No | A valid error message is shown when a non-existent host is deleted |
| Update SNMP host severity level | Yes | Yes | Not Applicable | Any drift observed from EFA configured default severity level is reconciled |
| Update SNMP host source interface | Yes | Yes | Not Applicable | Any drift observed from EFA configured default source interface is reconciled |
| Update SNMP host UDP port | Yes | Yes | Not Applicable | Any drift observed from EFA configured default UDP port is reconciled |
| Update SNMP host VRF | Yes | Yes | Not Applicable | Any drift observed from EFA configured default VRF is reconciled |
| Update SNMP host engine id | Yes | Yes | Not Applicable | |
| Update of SNMP host notification type (traps, informs) | Yes | Yes | Not Applicable | |
| Update of SNMP view MIB OID access (included, excluded) | Yes | Yes | Not Applicable |
efa inventory device snmp
community createefa inventory device snmp
community deleteefa inventory device snmp
community listefa inventory device snmp
user createefa inventory device snmp
user deleteefa inventory device snmp
user listefa inventory device snmp
host createefa inventory device snmp
host deleteefa inventory device snmp
host listFor more information, see the Extreme Fabric Automation Command Reference, 3.0.0 .
NTP Configuration
The NTP commands let you configure NTP server configuration on the SLX device. The configuration you set is persisted in the EFA database. DRC is also supported.
The following table captures the various attributes of the NTP configuration interface for which DRC and idempotency is supported. A drift is identified if any of the following fields are modified by you through SLX CLI or other management tools. Reconcile operation pushes the intended configuration to SLX which makes the SLX configuration synchronize with EFA.
On idempotency for creating an entry which already exists in EFA, an error message is returned stating that user already exists.
| Field | Identify Drift | Reconcile configuration | Idempotency | Notes |
| NTP auth key ID associated with NTP serer is modified | Yes | Yes | Not Applicable | |
| NTP auth key name associated with NTP serer is modified | Yes | Yes | Not Applicable | |
| NTP server deleted | Yes | Yes | No | A valid error message is shown when a non existent NTP server is deleted. |
| Encryption type is modified | Yes | Yes | Not Applicable | |
| Trusted key is modified | Yes | Yes | Not Applicable | |
| Encryption level is modified | Yes | Yes | Not Applicable | |
| NTP server disable modified | Yes | Yes | Not Applicable |
efa inventory device ntp
server createefa inventory device ntp
server deleteefa inventory device ntp
server listefa inventory device ntp
disable-serverFor more information, see the Extreme Fabric Automation Command Reference, 3.0.0 .
IP prefix list configuration
Regarding idempotency for creating an entry which already exists in EFA, an error message is returned stating that the user already exists.| Field | Identify Drift | Reconcile configuration | Idempotency | Notes |
| IPv4 prefix list rule is deleted. | Yes | Yes | No | Deleted rule will be reconciled. |
| IPv4 prefix list is deleted. | Yes | Yes | No | Deleted prefix list along with all rules associated with it will be reconciled. |
| IPv4 prefix list rule created OOB. Different rules exist with same prefix list name in EFA. | No | No | Not applicable | Delete the OOB rule or keep it and don‘t act as part of DRC. |
| IPv4 prefix list rule created OOB. Different rules exist with same prefix list name and sequence number in EFA. | Yes | Yes | Not applicable | Prefix list rule will be reconciled to be in sync with EFA. |
| Create an IPv4 prefix OOB with a prefix list name not matching any of the EFA created entries. | No | No | Not applicable | These are treated as out of band entries and EFA will not perform DRC. |
Route map configuration
| Route map deleted. | Yes | Yes | No | Recreate the route map, along with the match criteria during reconcile. |
| Route map rule action updated. | Yes | Yes | No | Reconcile the route map action (permit/deny) for that rule. |
| Update IPv4 prefix list name in match criteria. | Yes | Yes | No | Reconcile the IPv4 prefix list name. |
| IPv4 prefix list match criteria deleted. | Yes | Yes | NA | Reconcile the match criteria for IPv4 prefix list. |
| A different match criteria NOT supported by EFA is added through OOB. | No | No | NA | |
| A set criteria NOT supported by EFA is added through OOB. | No | No | NA | |
| Route map is created through OOB and this is not present or created by EFA. | No | No | NA |
Device Settings
The following table captures the various attributes of device settings for which DRC and idempotency are supported.
| BGP prefix independent convergence (PIC) | Yes | Yes | Yes |
| prefix-independent-convergence-static | Yes | Yes | Yes |
| ECMP routed load-sharing max path | Yes | Yes | Yes |
| Maintenance mode convergence time | Yes | Yes | Yes |
| Static prefix independent convergence (PIC) | Yes | Yes | Yes |
Drift and reconcile and idempotency configuration support is not applicable for device update and viewing device settings.BGP Prefix Independent Convergence (PIC)
Specify Yes to enable BGP PIC and No to de-configure it.
After configuring this command, clear the routes on the device.For more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
ECMP Max Path
The device must be reloaded for this command to take effect.efa inventory device setting update
--maximum-load-sharing-pathsFor more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
Device Settings Update
Configure the maintenance mode and display the available device settings.
Use the device-ips parameter, separated by comma to view a range of device IP addresses.
Use the fabric-name parameter to specify the name of the fabric.
The show command displays the device settings.
efa inventory device setting show [ --ip device-ips ]For more information, see Extreme Fabric Automation Command Reference, 3.0.0 .
Time Zone Configuration
By default, SLX devices come up with the GMT timezone. Using the efa inventory device
timezone command, you can set the timezone per device or per
fabric.
| Time zone is set. | Yes | Yes | Yes |
| Time zone is unset. | Not applicable | Not applicable | Yes |
Identify drift, drift and reconcile, and idempotency support is not applicable for time zone display.For more information, see the Extreme Fabric Automation Command Reference, 3.0.0 .
