efa tenant service mirror session create –-name <session-name> --tenant <tenant-name>
           --source {<device-ip>,<eth | po | vlan>,<if-name>}
           --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
           --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
	                     <destination-device-ip>,<eth | po | vlan>,<destination-if-name}
           --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
           --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
(efa:root)root@node-2:~# efa tenant show
|     Name     |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |  Mirroring Ports    |
| sharedTenant | shared  |            |             |             |     0     |   false   |                       | 10.20.246.15[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.16[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.21[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.22[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.25[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.26[0/31]  |
|     ten1     | private |   11-20    |             |             |    10     |   false   | 10.20.246.15[0/1-10]  |                     |
|              |         |            |             |             |           |           | 10.20.246.16[0/1-10]  |                     |
|     ten2     | private |   21-30    |             |             |    10     |   false   | 10.20.246.15[0/11-20] |                     |
|              |         |            |             |             |           |           | 10.20.246.16[0/11-20] |                     |
(efa:root)root@node 2:~# efa tenant po show
|   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
|         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
| ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
| ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
                    | 10.20.246.15 efa tenant service mirror session create --name ten1mirrorsession1 --tenant ten1
                    --source 10.20.246.15,po,ten1po1
                    --type 10.20.246.15,po,ten1po1:port-based
                    --destination 10.20.246.15,po,ten1po1:10.20.246.15,eth,0/31
                    --destination-type 10.20.246.15,po,ten1po1:span
                    --direction 10.20.246.15,po,ten1po1:both | 10.20.246.16 efa tenant service mirror session create –name ten1mirrorsession2 --tenant ten1
                  --source 10.20.246.16,po,ten1po1
                  --type 10.20.246.16,po,ten1po1:port-based
                  --destination 10.20.246.16,po,ten1po1:10.20.246.16,eth,0/31
                  --destination-type 10.20.246.16,po,ten1po1:span
                  --direction 10.20.246.16,po,ten1po1:both |
| 10.20.246.15 efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
                --source 10.20.246.15,po,ten2po1
                --type 10.20.246.15,po,ten2po1:port-based
                --destination 10.20.246.15,po,ten2po1:10.20.246.15,eth,0/31
                --destination-type 10.20.246.15,po,ten2po1:span
                --direction 10.20.246.15,po,ten2po1:both | 10.20.246.16 efa tenant service mirror session create –name ten2mirrorsession2 --tenant ten2
                 --source 10.20.246.16,po,ten2po1
                 --type 10.20.246.16,po,ten2po1:port-based
                 --destination 10.20.246.16,po,ten2po1:10.20.246.16,eth,0/31
                 --destination-type 10.20.246.16,po,ten2po1:span
                 --direction 10.20.246.16,po,ten2po1:both |
| 10.20.246.15 SLX# show running-config monitor session monitor session 1 source port-channel 2 destination ethernet 0/31 direction both !monitor session 2 source port-channel 3 destination ethernet 0/31 direction both ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Po 2 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : port-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Po 3 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : port-based | 10.20.246.16 SLX# show running-config monitor session monitor session 1 source port-channel 2 destination ethernet 0/31 direction both !monitor session 2 source port-channel 3 destination ethernet 0/31 direction both ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Po 2 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : port-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Po 3 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : port-based |
