- When you run the efa inventory drift-reconcile
execute command, the tenant configuration
drift and reconciliation starts along with other services
(for example, inventory, fabric, and policy).
- During the
tenant DRC, first the tenant drift is identified, and then
the same drift is reconciled. The timeout for both tenant
configuration drift identification and reconciliation is 15
minutes.
- The inventory drift-reconcile execute command waits for the
tenant DRC response for 15 minutes. If the response is not
received within 15 minutes, then the DRC fails with the
reason code “tenant-dr-timeout”.
- The functionality is applicable for manual DRC and auto DRC
(triggers when the device is reloaded in maintenance
mode).
- In case of
scaled tenant configuration drift (for example, 2000 VE or
PO drifted and 100 VRFs drifted), the tenant can take more
than 15 minutes for drift identification and reconciliation.
Therefore, the DRC fails with the status
tenant-dr-timeout.
- The tenant configuration drift identification and
reconciliation run to completion in the background even
though the DRC fails with the status
tenant-dr-timeout.
- The subsequent DRC reflects the correct status of the
drift.
