You can configure the maximum transmission unit (MTU) when you create or update an endpoint group.
You use the --ip-mtu parameter (in the format
					ctag:value) to configure the MTU for the tenant network. This
				value is then configured on the interface VE on the SLX device.
$ efa tenant epg create --name ten1epg1 --tenant ten1 --port 10.20.246.17[0/1], 10.20.246.18[0/1] --switchport-mode trunk --ctag-range 11-12 --anycast-ip11:10.0.11.1/24 --anycast-ip12:10.0.12.1/24 --anycast-ipv6 11:11::1/127 --anycast-ipv6 12:12::1/127 --vrf ten1vrf1 --ip-mtu 11:7900 --ip-mtu 12:8900
vrf-add or ctag-range-add
					operations.
				$ efa tenant epg update --name ten1epg1 --tenant ten1 --operation ctag-range-add --ctag-range 12 --anycast-ip12:10.0.12.1/24 --anycast-ipv6 12:12::1/127 --ip-mtu 12:6990
ctag-range-add
					operation.
