Configure Route Map on devices
  1. Run the following command to configure the route map with one or more rules:
    efa policy route-map create ?
    Flags:
          --name string           Name of route-map
          --rule stringArray      Rule in format seq[seq-num],action[permit/deny]
    Following is an example of creating a route map rmap_1 with two rules:
    efa policy route-map create –-name rmap_1 –-rule seq[5],action[permit] –-rule seq[10],action[permit]
  2. Run the following command to update the route map configuration on a list of devices:
    The update command configures the route-map on device, removes configuration from a device or updates action of route-maps.
    efa policy route-map update ?
    Flags:
          --rule string      Rule in format seq[seq-num],action[permit/deny]
          --operation string Valid options are add-device, remove-device, update-action
          --ip string        Comma separated range of device IP addresses. Example: 1.1.1.1-3,1.1.1.2,2.2.2.2
    You can associate a route map with multiple rules.
    The add-device operation adds all the rules of the route map on the specified devices.
    The delete-device operation deletes all the rules of the route map on the specified devices.
    The delete-device operation fails if the route map is bound to any BGP neighbor.
    For an update-action operation, specify the route map name and the rule. You can modify the action to permit or deny for a specific rule. You can provide only one rule at a time.
    Following are the examples of route map configuration update:
    1. Add device: Configures a route map rule on devices 10.20.246.10 and 10.20.246.11. Assume there are two route map rules for a map named rmap_1 that already exists in EFA:
      • rmap_1 seq 5 action permit
      • rmap_1 seq 10 action permit
      efa policy route-map update –-name rmap_l –-operation add-device --ip 10.20.246.10-11
    2. Delete device: Removes route map from the specified devices:
      efa policy route-map update –-name rmap_l –-operation delete-device --ip 10.20.246.10-11
    3. Update action: Changes the action from permit to deny for the specified rule
      efa policy route-map update –-name rmap_l –-rule seq[5],action[deny] –-operation update-action
    1. Verify the switch configuration on the SLX device.
      Example 1
      SLX# show running-config route-map
      route-map rmap_1 permit 5
      Example 2
      route-map rmap_1 permit 10
      Example 3
      route-map rmap_1 deny 5
  3. Run the following command to create route map match criteria:
    The IPv4 prefix list is the only match supported.
    efa policy route-map-match create ?
    Flags:
          --match-ipv4-prefix string IPv4 prefix-list name
    Following is an example of route map match create in IPv4:
    efa policy route-map-match create –-name rmap_1 –-rule seq[5],action[permit] --match-ipv4-prefix prefix_1
      match ip address prefix-list prefix_1
  4. Run the following command to remove the route map match criteria:
    efa policy route-map-match delete ?
    Flags:
    Following is an example of route map match delete in IPv4:
    efa policy route-map-match delete –-name rmap_1 –-rule seq[5],action[permit]
  5. Run the following command to display the route map for a list of devices:
    In the command output, the App State column reflects the state of configuration on the specified device. When there is drift in a rule, the App State is shown as cfg-refreshed.
    efa policy route-map list ?
    Flags:
    Example:
    efa policy route-map list –-ip 10.20.246.10-11
    Route-map details:
    Seq: 5
    Action: permit
    Match-ipv4-prefixlist:
        Prefix-list: prefix_1
    Seq: 5
    Action: permit
    IP Addresses:
    |     Name     | Seq |  IP Address   |     App State     |
    | rmap_1       |  5  | 10.20.246.10  |    cfg-in-sync    |
    | rmap_1       |  5  | 10.20.246.11  |    cfg-in-sync    |
    | rmap_2       |  5  | 10.20.246.10  |    cfg-in-sync    |
    | rmap_2       |  5  | 10.20.246.11  |    cfg-in-sync    |
  6. Run the following command to delete a route map and the associated rules on the devices:
    efa policy route-map delete ?
    Flags:
           --name stringArray      Name of route-map
           --seq string            Sequence numbers. For example 5,10,20, or all
    The command removes the route map rule from the EFA database and from the associated devices.
    You can delete a specific rule of a route map by specifying the route map name and the sequence number of the rule.
    You can delete all the route map rules for a specific route map name by specifying the sequence number as "all".
    The result of this command depends on whether the route map is bound with a BGP neighbor.
    • If the route map is bound to BGP peer, you cannot delete the last route map rule.
    • If the route map has no bindings, the command deletes the configuration on all devices associated with the route map.
    Following example deletes two rules with sequence numbers 5 and 10 from a route map (rmap_1) that has three rules:
    • rmap_1 seq 20 action permit
      efa policy route-map delete –-name rmap_l –-seq 5,10
      SLX1# show running-config route-map rmap_1
      route-map rmap_1 permit 20
