EFA enables configuration of global router BGP listen-limit which depends on the router BGP dynamic peer scale requirements. Listen-limit configuration defined under the “global router bgp” context signifies the maximum number of dynamic BGP peers that can be operational across the VRFs in the SLX. Default value of the global router BGP listen-limit is 100, which you can modify with any value in the range of 1-2400.
Ensure that the listen-limit configuration defined at the “dynamic peer listen-range” level is less than or equal to the “listen-limit” configuration defined under the “global router bgp”. Pre-2.5.0 versions of EFA do not support configuration of global router bgp listen-limit.
The maximum number of dynamic BGP peers is limited to the SLX default (100), when provisioned through EFA.
Configure the new fabric setting for each fabric with bgp-dynamic-peer-listen-limit command. The fabric setting is
                applicable for Clos and small data center fabrics, and for all types of devices
                (leaf, border-leaf, spine, super-spine).
Configure the bgp-dynamic-peer-listen-limit value on all the devices of the fabric
                when you configure the fabric.
You can configure the bgp-dynamic-peer-listen-limit on an already provisioned fabric. For
                the new value to be effective, run the fabric configure
                command, followed by the efa
                    fabric setting update command. This enables you to configure bgp-dynamic-peer-listen-limit on the existing pre-2.5.0
                deployments.
You can only increase (but not decrease) the value ofbgp-dynamic-peer-listen-limit on an already provisioned
                fabric.efa fabric setting update –name <fabric-name> --bgp-dynamic-peer-listen-limit <1-2400>
| Rack1-Device1# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover listen-limit 200 neighbor 10.20.20.5 remote-as 4200000000 neighbor 10.20.20.5 next-hop-self address-family ipv4 unicast network 172.31.254.139/32 network 172.31.254.226/32 maximum-paths 8 graceful-restart ! address-family ipv6 unicast ! address-family l2vpn evpn graceful-restart ! ! | Rack1-Device2# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover listen-limit 200 neighbor 10.20.20.4 remote-as 4200000000 neighbor 10.20.20.4 next-hop-self address-family ipv4 unicast network 172.31.254.115/32 network 172.31.254.226/32 maximum-paths 8 graceful-restart ! address-family ipv6 unicast ! address-family l2vpn evpn graceful-restart ! ! |
