You can provide multiple anycast IP address per tenant ctag when you create or update
                an EPG, add ctag-range, add VRF, and add or delete anycast IP. The multiple anycast
                IP address is configured under the interface Ve of the
                switching hardware.
Multiple anycast IP configuration example when you create an EPG:
efa tenant epg create --name e1 --tenant tenant11 --po po1 --switchport-mode trunk-no-default-native --vrf v1 --ctag-range 101-102 --anycast-ip 101:1.1.1.254/24 --anycast-ip 101:2.1.1.254/24 --anycast-ip 101:3.1.1.254/24 --anycast-ipv6 101:1::1/124 --anycast-ipv6 102:2::1/124
efa tenant epg show –detail
Tenant        : tenant11
Type          : extension
State         : epgf-with-port-group-and-ctag-range
Description   :
Ports         :
POs           : po1
Port Property : SwitchPort Mode               : trunk-no-default-native
              : Single-Homed BFD Session Type : Auto
NW Policy     : Ctag Range                    : 101-103
              : VRF                           : v1
              : L3Vni                         : 8192
| MAC ACL IN | MAC ACL OUP | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
POrt Property ACLs
| Port |  Dev State   |  App State  |
| po1  | provisionied | cfg-in-sync |
Port Property States
| Ctag |    Ctag       | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 | Suppress |         Local IP         | IP MTU | IPv6 ND |    IPv6 ND     |     IPv6 ND  |  Dev State  |  App State  |
|      |  Description  |       |         |              |              |  ARP/ND  |   [Device-IP->Local-IP]  |        |   MTU   | Managed Oonfig | Other Config |             |             |
| 101  |   Tenant L3   |10000  |         | 2.1.1.254/24 |   1::1/124   |    T/T   | 10.20.246.3->1.10.1.1/24 |        |         |      false     |     false    | porvisioned | cfg-in-sync |
|      | Extended VLAN |       |         | 3.1.1.254/24 |              |          |                          |        |         |                |              |             |             |
|      |               |       |         | 1.1.1.254/24 |              |          |                          |        |         |                |              |             |             |
| 102  |   Tenant L3   |10001  |         |              |   2::1/124   |    T/T   |                          |        |         |      false     |     false    | porvisioned | cfg-in-sync |
|      | Extended VLAN |       |         |              |              |          |                          |        |         |                |              |             |             |
Network Property [Flags : * - Native Vlan]
| Ctag | IPv6 ND Prefix | No Advertise | Valid Lifetime | Preferred Lifetime | Config Type |
IPv6 ND Prefix Flags
| Ctag | MAC ACL Prefix | MAC ACL OUT | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
Network Property ACLs
For 'unstable' entities, run 'efa tenant po/vrf show' for details
| 10.20.246.25 SLX# show running-config interface Ve interface Ve 101 vrf forwarding v1 ip anycast-address 1.1.1.254/24 ip anycast-address 2.1.1.254/24 ip anycast-address 3.1.1.254/24 ipv6 anycast-address 1::1/124 no shutdown ! interface Ve 102 vrf forwarding v1 ipv6 anycast-address 2::1/124 no shutdown ! interface Ve 4090 ip address 10.20.20.2/31 no shutdown ! interface Ve 5120 vrf forwarding v1 ipv6 address use-link-local-only no shutdown ! | 10.20.246.26 SLX# show running-config interface Ve interface Ve 101 vrf forwarding v1 ip anycast-address 1.1.1.254/24 ip anycast-address 2.1.1.254/24 ip anycast-address 3.1.1.254/24 ipv6 anycast-address 1::1/124 no shutdown ! interface Ve 102 vrf forwarding v1 ipv6 anycast-address 2::1/124 no shutdown ! interface Ve 4090 ip address 10.20.20.3/31 no shutdown ! interface Ve 5120 vrf forwarding v1 ipv6 address use-link-local-only no shutdown ! |
Multiple anycast IP configuration example when you update an EPG:
efa tenant epg update --name e1 --tenant tenant11 --operation anycast-ip-add --anycast-ip 101:4.1.1.1/24
| 10.20.246.25 SLX# show running-config interface Ve interface Ve 101 vrf forwarding v1 ip anycast-address 1.1.1.254/24 ip anycast-address 2.1.1.254/24 ip anycast-address 3.1.1.254/24 ip anycast-address 4.1.1.1/24 ipv6 anycast-address 1::1/124 no shutdown ! interface Ve 102 vrf forwarding v1 ipv6 anycast-address 2::1/124 no shutdown ! interface Ve 4090 ip address 10.20.20.2/31 no shutdown ! interface Ve 5120 vrf forwarding v1 ipv6 address use-link-local-only no shutdown ! | 10.20.246.26 SLX# show running-config interface Ve interface Ve 101 vrf forwarding v1 ip anycast-address 1.1.1.254/24 ip anycast-address 2.1.1.254/24 ip anycast-address 3.1.1.254/24 ip anycast-address 4.1.1.1/24 ipv6 anycast-address 1::1/124 no shutdown ! interface Ve 102 vrf forwarding v1 ipv6 anycast-address 2::1/124 no shutdown ! interface Ve 4090 ip address 10.20.20.3/31 no shutdown ! interface Ve 5120 vrf forwarding v1 ipv6 address use-link-local-only no shutdown ! |
