Device backup is integrated with the existing system backup CLI.
Additional parameters allow you to specify either the fabric name or list of devices for which to run a backup.
There are commands for showing and updating backup settings.
efa system settings show
lets you display all the system settings that have been
configured.
efa system settings show +----------------------------+-------------+ | SETTING | VALUE | +----------------------------+-------------+ | Max Backup File Limit | 5 | +----------------------------+-------------+ | Max Supportsave File Limit | 5 | +----------------------------+-------------+ | Backup Schedule | 0 0 * * * | +----------------------------+-------------+ | Remote Server IP | 10.20.241.7 | +----------------------------+-------------+ | Remote Server Username | root | +----------------------------+-------------+ | Remote Server Password | **** | +----------------------------+-------------+ | Remote Server Directory | /root/vinod/ | +----------------------------+-------------+ | Remote Transfer Protocol | scp | +-------------------------------+-------------+ | Periodic Device Config Backup | yes | +-------------------------------+-------------+ --- Time Elapsed: 831.836375ms ---
For more information, see efa system settings show in the
Extreme Fabric Automation Command Reference,
3.0.0
There are settings for configuring remote server details where the backup is copied. In case remote server details are missing, the backup is copied on the same server where EFA is installed, which is also the current behavior of the system backup.
Passwords are encrypted using an AES algorithm and stored in the database.
Remote server validation is performed to validate whether the provided details of a remote server are valid or reachable (if you enter only an IP address, the application checks in the database for the remaining parameters - if they are missing, then it is treated as an error). All four parameters (IP, username, password, and directory-path) are expected for validation, either from the user or the database.
Transfer of a backup archive on a remote server is done through the SCP protocol.
The efa system settings
update command lets you make the updates.
efa system settings update --remote-server-ip 10.20.241.7 --remote-server-username root --remote-server-password pass --remote-server-directory /root/vinod/ Setting Update Successful --- Time Elapsed: 148.800033ms ---
You can reset the updated system backup settings to default values.
The efa
system settings reset command lets you make the updates.
efa system settings reset --max-backup-files Reset System Settings is Successful
system settings reset in the Extreme Fabric Automation Command
Reference Guide.
To perform the backup, use the efa system backup command with
options for specifying fabric or device details.
For more information, see efa system backup in the
3.0.0
The following backup scenarios showcase the use of different options with the
efa system backup command.
Run system backup on remote
efa system backup --remote Generating backup of EFA... Backup Location: /var/log/efa/backup/EFA-3.0.0-110-2022-03-28T11-37-00.936.tar --- Time Elapsed: 5.741750131s ---
Run system backup without device configuration backup
efa system backup --remote Generating backup of EFA... Backup Location: root@10.20.241.7:/root/vinod/EFA--3.0.0-110-2022-03-28T11-37-00.936.tar --- Time Elapsed: 5.741750131s ---
Run system backup by taking configuration backup of all devices that are part of the fabric specified
efa system backup --fabric default --remote Generating backup of EFA... Backup Location: root@10.20.241.7:/root/vinod/EFA--3.0.0-110-2022-03-28T11-37-00.936.tar --- Time Elapsed: 5.741750131s ---
Run system backup by taking configuration backup of all fabrics and its devices
efa system backup –-fabric-all --remote Generating backup of EFA... Backup Location: root@10.20.241.7:/root/vinod/EFA--3.0.0-110-2022-03-28T11-37-00.936.tar --- Time Elapsed: 5.741750131s ---
Run system backup by taking configuration backup of all devices that are specified
efa system backup --device-ip 10.20.1.2,10.20.1.3,10.20.1.4 --remote Generating backup of EFA... Backup Location: root@10.20.241.7:/root/vinod/EFA--3.0.0-110-2022-03-28T11-37-00.936.tar --- Time Elapsed: 5.741750131s ---
Error message: Fabric does not exist
Backup is partially success:
Error message: Device not found
efa system backup --device-ip 10.20.1.5,10.20.1.6 --remote
Device 10.20.1.5 not found
Error message: Operation not allowed
efa system backup --device-ip 10.20.1.2,10.20.1.3 --remote
Devices [10.20.1.2] failed to get config backup as its locked for configuration change by process [Firmware download].
Existing features of the wider backup schedule work here, too. Additionally, the backup gets SLX configuration backup of all those devices that are associated with a valid fabric.
