Northbound Interface Certificates
        The certificate is bundled with EFA and signed by the private Certificate Authority (CA)
            Chain. So that the certificate can be replaced with a third-party certificate acquired
            through trusted CAs (such as Verisign or GoDaddy), the certificate must be present in
            the host device that is running EFA. You can then install it with the following
            command:
$ efa certificates server –-certificate <cert-filename> --key <key-filename> --cacert cert-filename
Important
                    - If you install your own
                        server certificate to use with the EFA HTTPS server, remember to reinstall
                        the certificate when you upgrade EFA.
- Generate the third-party
                        certificates and keys without a passphrase. Certificate installation may
                        fail if you generate the third-party certificates and keys with
                        passphrase.
        Communication with third-party certificates in an EFA installation is enabled on the
            following ports:
                - 443: Secure installation of
                    EFA
- 8078: Monitoring service of EFA
 For information about third-party certificates in a multiple management IP
            network, see
Configuration Supporting Multiple Management IP Networks.
For a multi-node deployment, EFA uses the common name (CN) of the virtual IP address and
            a Subject Alternate Name containing the virtual IP address and the node IP addresses.
        Example for a single-node
            deployment:
Subject: CN=efa.extremenetworks.com
            X509v3 Subject Alternative Name:
                DNS:efa.extremenetworks.com, IP Address:127.0.0.1,
IP Address:10.24.15.173
Example for a multi-node
            deployment:
                DNS:efa.extremenetworks.com, IP Address:127.0.0.1, IP Address:10.24.15.178,
IP Address:10.24.15.174, IP Address:10.24.15.253
