Updated Fabric Settings and corresponding modification codes are
            displayed.efa fabric show output: ... Updated Fabric Settings: BGP-LL FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range..
app-state, drc-drift, and
                    drc-reconcile show outputs.--loopback-ip-range--p2p-link-range-mctlink-ip-rangeoopback-ip-range, p2p-link-range, and
                        mctlink-ip-range settings. Ensure that the prefix mask
                    length is lower than the configured prefix mask length value within the same
                    network.‘efa fabric show‘ output sample: ... Fabric Name: fs, Fabric Description: , Fabric Type: non-clos, Fabric Status: settings-updated Updated Fabric Settings: MCTLR,P2PLR,LOIP FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
--bfd-enable <yes|no>--bfd-tx <val>---bfd-rx <val>--bfd-multiplier<val>‘efa fabric show‘ output sample: ... Fabric Name: fs, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: settings-updated Updated Fabric Settings: BFD-ENABLE,BFD-TX,BFD-RX,BFD-MULTIPLIER FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
router BGP, interface links, MCT
                        port-channel interfaces, and pushes the configuration to the SLX
                    devices.| Cannot be Updated | Can be Updated | Invalid Settings for Small Data Center Fabric |
 --backup-routing-ipv6-range |
 --bgp-dynamic-peer-listen-limit |
 --default-mdtgroup |
| Cannot be Updated | Can be Updated | Invalid Settings for Clos Fabric |
 --rack-overlay-ebgp-peer-group |
