You can determine the session type for a Bidirectional Forwarding Detection (BFD) session formed over a Cluster Edge Port (CEP) port.
You can assign a session type as you create an endpoint group. You can also assign a session type to an existing endpoint group.
The default is auto, which means that the BFD session type is automatically determined based on whether the service type is set to extension (software) or Layer 3 hand-off (hardware).
The value of --single-homed-bfd-session-type is configured for one endpoint group
				and then propagated to all Ethernet and single-homed port channel interfaces defined
				for that endpoint group.
EFA does not distinguish between SRIOV (single-root input/output virtualization) and non-SRIOV
				connections. Therefore, it treats both connections the same way. If you want to use
				hardware-based BFD sessions for CEP non-SRIOV connections, then create an endpoint
				group that contains all the CEP non-SRIOV connections and set the --single-homed-bfd-session-type to hardware.
$ efa tenant epg create --name epg5 --tenant tenant11 --port 10.20.216.15[0/11] ,10.20.216.16[0/11] --po po1 --switchport-mode trunk --single-homed-bfd-session-type auto
$ efa tenant epg update --name epg5 --tenant tenant11 --operation port-group-add --port 10.20.216.15[0/11],10.20.216.16[0/11] --po po1 --switchport-mode trunk --single-homed-bfd-session-type hardware
