In SLX versions prior to 20.3.2:
But this restriction is removed from 20.3.2 onwards.
The timer values provided directly at the “router bgp” level are effective only for the multi-hop BFD sessions of both default and non-default VRF BGP peers.
The timer values provided directly at the “router bgp” level are effective for both multi-hop and single-hop BFD sessions of both default and non-default VRF BGP peers.
Prior to upgrade of SLX-OS, ensure that you enable the maintenance mode on reboot using the efa inventory device setting update --maint-mode-enable-on-reboot Yes –ip <IP address of SLX> command. If you have upgraded SLX-OS without enabling the maintenance mode, trigger a manual drift and reconcile (DRC) using the command efa inventory drift-reconcile execute --ip <IP address of SLX>” –reconcile.
If you have
                        not triggered the manual DRC, the efa fabric show --name
                            <fabric name> command shows devices in cfg-refreshed
                        state, and the intended BFD configuration does not get configured on the
                        devices.
